Sign in to follow this
steved35
How too 2.4 zetec
I don't know the answer, but I'd like to know. We were talking about a 2.3 or 2.4 Pinto recently, but as far as I can see, I'd have to stroke it, which would reduce the max RPM, which would in turn remove some of the max power.  :-s
Stroking a pinto doesn't reduce the max power, rather it increases the torque and reduces the rpm needed to achieve it. My 2.2 Pinto has plenty of grunt without needing a zillion rpm to achieve it.
Is it a zetec that they have in the galaxy? They do a 2.3 version of that, maybe its just an overbore ? No idea of power or what it revs like?
In my day it was side valve with aqua plane tuning equipment not fancy black boxes and lumps you couldn't do anything with
The Galaxy 2.3 is a completely different engine to a Zetec
The Duratec 2.3 is a US Version as is the 2.5 found in the Ranger
Mostly it's a long stroke crank as some have bought the Ranger crank and put that in a Duratec with different rods & pistons
With the 2.0 Duratec capable of 200bhp in standard form and over 220 with a pair of cams it does seem to be an expensive way to more power.
The Pinto gets
2091cc with 93mm pistons
2136 with 94mm pistons
2228 with 93mm Pistons and 82mm stroke
2283 with 93mm pistons and 84mm stroke
2337 with 93mm pistons and 86mm stroke
2391 with 93mm pistons and 88mm stroke
2443 with 94mm pistons and 88mm stroke
I think after 84mm stroke you need to release the block and the bottom of the bore you will also have trouble with pump and pickup most would go dry sump
That's cheating vista changing people's posts! Back to my day what came out the back could be put to good use around the roses and potatoes, not kill you as the gases do today or is there some physasist out going to tell me different? Probably spelt wrong and the wrong word but who cares
Ah, interesting.
When building a decent pinto, IIRC you need to deck the block so the pistons sit proud very slightly. Raises compression too.
we are talking zetec trying to lol
Same applies.to any engine build check deck heights to establish comp ratio
If no-one has done this conversion then it's a case of suck it and see. Be prepared to throw some money away by getting the wrong parts and if you can't do the machining yourself be prepared for some hefty bills with the view it may not work! So be prepared. You don't get anywhere unless you try good luck mate
Pinto and Zetec need different approach regarding block decking
The Pinto needs 0.9mm for a road car between head & Piston with a standard gasket you can have piston out of the block
With 1mm gasket your better flat
Plug electrode may be the closest point to the piston @ TDC if head skimmed
Zetec runs higher compression as standard and most would fit forged Pistons and overbore, how much I don't know
To be hones perusing the ultimate of any engine is costly and I often think "what's the point" when you can just move up an engine for less money
Crossflow to 160bhp
Pinto to 180 bhp
Zetec to 195 bhp
Duratec 200 to 260 and upwards
It's fun though. I'm building a super-charged Pinto. I'm hoping for 160bhp. I could buy a scrap Mondeo and have that much power off-the-shelf for a lot less money and time, but building an engine up myself and eeking out some more power is fun...
What's the point , ? I run 220 zetec to put a duratec in surly would cost more than may be getting 260 from a zetec it was grunt than bhp and wonder what sort of numbers we were talking and more of how things are done there's 2.2 2.4 pintos out there now what would be the point of that !!
good luck with that nice to see some one doing something u don't see every day
  • Like 2
Whats the maximum overbore on a 2.0 zetec? Does it go +30,60,90? Would something like a +90 give you nearly 2.1 like a 2.0 pinto, if thats right? Or am i talking out of my bottom? Whats the thinking of wanting to go bigger, it went well on the trips to and from mk! You getting a bit worried about your lads duratec install? Hehe
