preacherman
Pinto cylinder head torque settings and procedure
Putting a new head gasket on the pinto 2.0 using Torx stretchy bolts.
Can someone advise the correct procedure for
sequence of torquing
torque settings initial and afterwards
Any other tips etc
What is a very good brand of head gasket to use ?
Cheers
Neil
Those torque settings will be for the early type reusable splined bolts, not the single use Torx stretch bolts. Same torque pattern but slightly different procedure and settings. 624c9b52aba6fb0e868854f32e9cdbc2.jpg
Sent from my SM-A320FL using Tapatalk
Very interesting, HotRodMatt. I've recently refitted my head and followed the guidance of the Haynes book and went midway at stage 4. I might need to recheck soon then following your notes.
I'm planning on taking the rocker cover off anyway for a little tinker in there, so ideal opportunity.
