voodoo57
Vaud Escort 4 door mk2
Microsquirt arrived, gearbox has been swapped, re-drilled the hydraulic pipe fitting from the top to the side of the box for easier access to the Bias pot so all was going well, until...... The engine would only turn manually half way!
Now put back a tad, heads coming off today!!
Well............ it's not good news! the engine is ****ed! Lifters are naff, cams won't re-seat, timing was out, bottom bolts were loose, it's not a good sign! I bought the engine a good 4/5 years ago, it had a new belt, new valves, didn't bother to try to turn it over as if it didn't work, it would have gone straight back again! so a bit of a risk for the Scottish Oil rig worker who sold it to me,
so, instead of dropping a Ford into it, i am going to press on with the vauxhall power-train and search for another or similar... maybe a Saab engine? After all, i have spent money and time on the chassis engine mounts, propshaft, exhaust manifold, Gearbox mount, and ancillaries etc etc... leaves a large hole in my pocket but can't turn back now, i am obviously keeping the R25/28 box and as far as i know, it's only the vauxhall stud pattern that fits, unless i get a conversion plate made? Then the engine mounts will be out for whatever engine is decided on that's non Vauxhall..... Can't cry about it, just need to keep moving in the right direction.
to add insult to injury, one piston is bouncing from side to side in it's cylinder housing! obviously has been broken, had new valves fitted and then sold on.... although the engine has not been touched for years, i don't think the 'little people' who come out at night have managed to do this?
I won't be buying from oil rig workers in Scotland again!
What's your next step with the engine or you going to look for another unit ?
Regarding the Saab engine, there is a chap who has one that is the same bolt pattern for the R25/28 box?  but i need to read up on these a bit more, however, i am waiting on a mechanic a few miles from me to tell me a rough price to re-bore the cylinders and make the whole engine good again, he is a bit of a whizz with a lathe, and i may have him replace the cams with uprated ones, then again, if i can find another unit cheaper than what he quotes, i will go with that. Because of the amount of work going into this, i need to stick to a Vauxhall of sorts. The coscast head will go again, but the cams won't turn properly at present so i am hoping it's not too much to mess about with? I am def' not pulling everything out and going down the simpler route of zetec or pinto etc etc.. nor will i sell it as an on going project, got to stick with it, even if it means selling the Bread van before that's finished to continue funding the Escort.
looks like i am going ahead with the rebuild, uprated cams, and a full going over, Saab engine was a good choice, lots of power, but a lot heavier, got a few things to carry on with, as well as sourcing the last few bits needed for the car itself.
Thanks for that, I will def' bear that in mind. Any idea on the price of these? def' something to think about if the rebuild becomes costly, the guy also mentioned that he had a couple of coscast heads same as mine, but with minor damage & uprated cams... hmmmmmmn. Thanks again guy's.
Don't be hoodwinked into you must have a coscast head you DONT !
no, i realise that, but if it can be saved, (it looks pretty good) just the cams won't turn, they are solid even after the bolts being tightened a fraction, i just need to keep the cost down, and get the lump or A lump back into the engine bay and continue, i am certain all will be well, if not.... i will make it so! Thanks again colr6
New engine sorted, all going ahead well, trigger wheel and sensor fitted thanks to Chris Isaacs in Shotgate, picking it up this week to drop into the bay, then time for the ecu etc...
and then to source a reputable rolling road tuner, the engine is a good one, forged, with uprated cams, lots of head work, quite high compression so should work well with the throttle bodies, More details to follow. Hoping to be using this by November!
No i didn't, i was so angry at the latest, i just unbolted them, threw them in the scrap, and have kept the coscast head as a spare, but hopefully i shouldn't need it with this other engine, I felt that no matter what the problem was, it wouldn't make me feel any better, but at least things are back on track, and it should not take too long to sort the ecu and then finally the rolling road session, cheers dude!
bought all gaskets, so just a case of bolting the inlet etc on, sort the interior, find a rear bumper, windscreen washer bottle & headlights, all fluid levels are done and checked twice,
then over to Chris Isaacs who will sort the ecu, then rolling road time!
Hi, The Consul sold after it ended, it was bought by a guy in the North, he was over the moon!  I take it we are talking about the zetec estate? otherwise,
the 4 door one (blue) is still in the yard, too many jerk off's asking silly questions, so got fed up and took it off. it may be broken for parts now?
Still have a 4 door Zephyr for sale, def' project but rolling.........
Anyway, rear shocks have been ordered for the Vaud Escort, front bumper irons on their way (never thought i would have to buy these!) still waiting/looking for  a rear bumper & irons  and a pair of windscreen washer jets, That's about it!
