Sign in to follow this
binksy73
Rear Seat Cross Member.
Hi Can anyone give the me the measurements for the position of the rear seat cross member? I have positioned mine where I think it should be but the marks I made are a little faded. I have it positioned at 597mm with the tape hung from the bottom edge of the triangle cut out in the rear firewall to the top edge of the front face of the cross member.
Any help much appreciated.
Steve.
It's difficult to give you an exact measurement as there are so many discrepancies with these shells. Have you put a new full floor pan in or are you just changing the seat crossmember? When I put my full floor pan and crossmember in I lined the crossmember up with the seam of the crossmember where it meets the floor just behind the oval shaped pressing in the floor....then I trial fitted the rear seat base to see how it fitted. Hope this helps.
