mike399
What does everyone use to paint underneath there projects.
Hi all. Finally started my own project. Mk6 fiesta RWD. After owning the car for 16months.
All stripped and in process of cleaning every thing off the underneath. Ready for the welding to begin.
I plan to use Neutrarust 661 on the rusty bits. Which there isnt many bits.
And then fully paint underneath after all the work has been done. What I'm looking for is best thing to use,
I was gona stonechip it all. But looking for ideas,
Cheers all. be04042231c3be1d1b41fe8342b423d7.jpg3c5185f96db47f37373bd07dbe6109f2.jpgff4fea6130fb8c2e97c3e7ae89a4d74c.jpg7a1b54f85b046c94109d86d0af42d3df.jpg
Sent from my SM-T560 using Tapatalk
For my road cars I use bitumen and spray it on with a Shultz gun.
Easy quick and cheap, and can be done anytime needed.
The bitumen is available from the hardware, the Shultz gun from an auto paint store.
The bitumen will need to be thinned a little with turps so it can be sprayed.
I spray two heavy wet coats then leave for a few days to a week, then spray another two heavy wet coats.
And always remember to wear a mask and old clothes.
The bitumen acts as a rust preventative, and sound deadener.
For show and concourse cars I always bare metal, treat with phosphoric acid, two pack etch and undercoat then Gravitex sprayed on with the Shultz gun then black two pack paint.
:-D
use raptor it can be coloured with 2k paint
But all the raptor I've seen are black. Some of um say tint. But I want to paint it white underneath.
Sent from my SM-N9005 using Tapatalk
I’ve had raptor put under mine. Get 2 pots as one just wasn’t enough (even though they stretched 1 pot out on mine) it’s very thin in places. Get the clear one and colour it.
Por15 is supposed to be amazing but never tried it
Sent from my SM-G950F using Tapatalk
I always use waxoyl for the inside of the chassis rails, all along front to back, (or back to front depending where i lay) and as i lay underneath i ask myself.... 'if i was water, where would i sit and rot?' so then i use fibreglass resin in all the nooks and crannies, then when dry, i spray a primer over the area, and then what the guy's have suggested, Shultz.
I like ur idea voodoo. But I ain't got to lay underneath as she.s up on a spit.
So makes the whole thing easy.
It certainly does, and at least if you were to use anything 'runny' it would get right into the areas where they are known to rot, keep up the good work, thumbs up!
Thanks voodoo.
Still buzy cleaning down all underneath. Ford's underseal and seam sealer. Is a ba#### to remove
I used to use a paint scraper, blunt screwdriver and a blunt chisel (with the help of a hammer)  along with a good dose of petrol... I think? No more time for talkin' get stuck in!!!
Have you finished???????
Is the engine in??????? :mrgreen:
Well after a week of wire brush equipped grinder. Hot air gun ( to soften seam sealer ) and scrapers. Shes nearly all cleaned off underneath. 6c392f34236342efec7145fde34108c3.jpgc8301f8cf495d56dedf95bc21d1f2cf4.jpg58546d527925ece1ae50457fbdb9d3e9.jpg
"What does everyone use to paint underneath there projects"
In answer to the original question, I thought the answer was:
"Other way up!" :ykt:
I'll get my coat and shut the door behind me.:dope:
They say the old ones are best.......oh well...........lock the bloody door on your way OUT!!!
  • Haha 1
Fiesta rwd. Here is my RX8 6speed gearbox to go in just got to find a nice st 170 engine to go with it now. b25ad151b475e3cef9542853ee03e055.jpg
Hope your going to do an in depth build thread with loads of pics on this one, not the normal conversion so should be interesting
Hi colr6.
Yep that's the plan.
done a rwd conversions in the past. Mk3 rs turbo to RWD yrs ago.
quietly buying all the bits I need for this fiesta conversion as i go.
Did you find anything re the speedo ? I did think if you could get the likes of speedy cables to do an electronic speedo within your original clock, so it look original with modern guts. Could be worth a call.
List of parts so far. Rear sierra cosworth rear beam, brakes. And brand new gaz coilovers with 185 lbs springs. Rose jointed rear antiroll bar drop links, refurb lsd diff, sierra cosworth front crossmember and new power steering rack. Zx9r carbs. Rx8 gearbox. To name just a few bits I've got. Looking forward to the build928d492ac888e94d560e5001b7f48c45.jpg0c0138affa674608726d4f8b3ebdc37f.jpg017d6a9457074af2487849afa7429624.jpg8ebc6157e93f974a045a05bb092dcd6f.jpg638ff2f1349337e7e355e19aa69ba223.jpg03091983f173de1b807e21088a1935a9.jpg073ace2b5c89cdf7709211b382bf0c1e.jpg91f0cfeba85753b30c833f45b0854f15.jpg022af11c738510739d6d1842a99e2af6.jpgc1044b759c523c269f0d2ef929237e74.jpg498914a8353861d6301457581464f577.jpg21e440209ad8db646eb1bc385e7b1d2a.jpg
Haven't sorted anything as yet. I have used speedy cables loads of times before. Might be worth a call to check. I add it to my list of things to do.
How does the Sierra suspension go with the fiesta shell re the width, the Sierra is quite a wide track. Are you arching it ?
Rear sierra track is only 20mm wider than fiesta track.
Front is going to be made up of. Sierra crossmember with mk2 escort TCA. Fitted to grp4 coilover struts, by my measurements that will also work out at 20mm wider.
Just will need to measure up when I decide what wheels I'm gona be running. Don't want go fitting arches. Wana keep it looking sleeper ish.
