Duncanoakes
Should my mk2 have a header tank
Sorry to ask the ignorant question
I’ve got a mk2 , been under a dust sheet for ages and I don’t know a great deal about it
ive done a few posts on here 18 months ago when I bought it
anyway. It’s a mk2 rally car, started life as a 1.6 sport but now has a 2.0 pinto
there is no header tank for the coolant system. Is that correct?
slight leak on the radiator that I need to sort out by want to sure I’ve got the basic set up correct
its also had the pipes removed from the heater which is a little inconvienient !!!
any knowledge would be greatly received
Hi you don’t have a header tank the radiator has a header built in and filled via the cap, as for the heater it’s probably disconnected because the matrix leaks
If you have a normal top fill rad then you don't need a header tank, is the heater still in but disconnected or no heater
Thanks both
the Heater is still there but fans also don’t seem to work. Haven’t ever had chance to investigate
anyone reputable about to carry out repairs
or do I just wire hair driers under the dash board?
If you can find the two wires which go to the heater motor. One Is feed one earth put a battery or 12 volt supply and see if the motor works before pulling the heater out. Same goes for the water, pipe it up and see what happens.
8 minutes ago, Xp197777 said:
Yep that’s a overflow  standard top fill rad that’s fine
Thanks. On the hand full of times I’ve driven it there has been evidence of water from the overflow. And the engine didn’t appear to be running excessively hot. Does that suggest the caps knackered or maybe Rad is overfilled
Logical approach. I’ll give that a whirl
You still have to leave a bit of free space in the radiator for expansion of the hot coolant, so possibly overfilled.
Heater might be capped off if your inlet manifold has been changed and doesn't have a coolant connection.
