murfeey
Mk2 rs 2000 rear brakes
Do u set up shoes on drums first then bleed .all new lines fitted or bleed first cheers murf
It shouldn't make any difference really, if the self adjusters are working correctly, fit everything, bleed and it will adjust itself. If not, do it manually before or after you bleed.
Paul
You can drill a 10mm hole in the drum so you can manually adjust with a flat bladed screwdriver once the drum is on, you'd be surprised how much more adjustment you can get on them. Most drums have a wear lip which you have to get over, but once on the gap between shoes and drum could be as much as 4mm overall
