Sign in to follow this
smuudge
Capri Mk1 3000GXL VIN chassic decode
Guest chriscapriman
stolen from capripower :thumbsup:
http://www.capripower.co.uk/forum/index ... g-decoded/
This first example pic below was of the first type seen/used (1968-1972) on a British built Ford Capri.[/size]
Explanation of VIN plate=
Drive (British upto 1970) 1= right hand drive, 2= left and drive
Drive (British from Aug 1970 and German capris from Dec 1968) 1= left hand drive, 2= right hand drive.
Eng (Engine) S or J2= 1300cc high compression, T or J1= 1300cc low compression, U or L2= 1600cc high compression, W or L1= 1600cc low compression, R or J3= 1300cc GT, X or L3= 1600cc GT, N= 2000cc, H= 3000cc.
Trans (Transmission) 5= Floor change manual, 7= Floor change Automatic
Axle A= 3.545:1(3.444:1 to Aug 1970)( Z= heavy duty 3.545:1 from Aug 1970).
B= 3.778:1 (W= heavy duty), C= 3.889/3.900:1 (V/J = heavy duty), D= 4.125:1 (X= heavy duty),
E= 4.444:1 (Y= heavy duty), S/8= 3.444:1 (Z= heavy duty to Aug 1970, Q= heavy duty from Aug 1970), R= 3.221:1 (U= heavy duty).
Trim (this section is incredibly detailed upto Aug 1970 so only a couple of typical examples listed.)
Body (this is not highlighted on VIN plate, but is letter after trim code) D= De Lux, G= GT.
SVC ref: = Denotes date of manufacture, in case of a vehicle shipped unassembled for assembly in another country.
Vehicle Number This consists of : Six letters =
1st letter denotes country of origin (or in which assembled) B= Britain. D= West Germany
2nd letter denotes assembly plant; Right hand drive; B= Halewood Left hand drive; A= Cologne, West Germany
3rd letter denotes model type; E= Capri
4th letter denotes body type; C= 2 door coupe
5th & 6th letter denote year and month codes, which are translated for you in the table below (applying to all Capris from 1968 to 1986).
Which now leaves us with a figure number = This is the vehicle identification number, unique to the individual vehicle.
Example explanatory image below..
The only difference between these two plates shown is the left hand/right hand drive code number has changed.
September - Year 1972
The Vin Plate design/Layout changed again.
The Vin plate above is for Capris built in Britain, however production of the british built Capri ceased in September 1976, so,all Capris produced after that date would have the Vin plate shown below which was used by the West Germans since 1972.
This Vin plate contained information similiar to the previous Vin plate, but here is a description of the codes:
GECP = Capri coupe, West Germany.
BECP = Capri coupe, great Britain. (example below)
Version = applies to Italian cars only
Fahrgestell/Vehicle no (6 letters):
First letter denotes country of origin (or in which assembled)
B = Britain
G = Germany
Second letter denotes assembly plant
A = Cologne
D = Halewood
C = Saarlouis
Third letter denotes model type:
E = Capri
Fourth letter denotes body type;
C = Two door coupe
Fifth and sixth letters denotes year and months codes (see image immediatley below).
the six figures that follow on after the year and month code is the vehicle identification number unique to the vehicle it is on.
And here is a explanation of the rest of the Vin plate:
Lenk/Drive:
1 = Left-hand drive
2 = Right-hand drive
Motor/Engine: Denotes engine capacity and type:
J2 = 1300cc OHV
J3 = 1300cc OHV - Performance
LC = 1600cc OHC
LE = 1600cc OHC - Performance
NE = 2000cc
YY = 2300cc
PR = 2800cc
HY = 3000cc
just to add to this if you have ED instead of EC in the chassis number, the car was a development there are a few about and (according to ford) no car in the ford history ever had the ED they do exist i know of three one i owned another is in belgium and the other is still on the road and being used regular (met the guy at the capri`s at the ace one year)
That guy at the Ace was Chris. He was the previous owner the car you talk about, which I'm now the proud ownder of. :-D
The VIN begins BBEDHT. This leaves me clueless as to where it was built?
In regards to the ED coding denoting a development model, I met some folks from the Mk1 Owners Club last year, who were adamant that the ED thing had nothing to do with development. Again I'm left clueless.
They were clear that it was the oldest Capri that they know of (according to VIN sequence). Whilst I'm not 100% hung up on it being the oldest or a dev model (just happy to drive the car), I am curious to get a definitive answer to support this post.
I was indeed the owner - hows it going jimbo?  The car was built in Halewood and as proof postitive when I stripped it down for rebuilding there was  athrupenny bit glued in the floor - still got it somewhere
