MK1 Escort 4door Restoration with light Mod's
MrKing
 Share
I'm reasonably new and have been encouraged to start a log of the Restoration so below is how i got it...
And so far...
front panel rotten through
so cut it out
new panel offered up and seemed ok
new strength bolted/welded in
grill checked for clearance whilst finishing some tacking in place
both rear door were quite good so a good rub down i little filler and primmed then thought about maybe doing it Mercury Grey?
i'm undesided about the colour atm plenty to do whilst i think it through
Believe it or not after just a few tinkering hours and a new ignition coil i got her running (not been ran for 20+ years!)
Spoiler gone! - it wasn't to my taste.
and briefly this morning i tacked in a new plate as the petrol tank didnt have any metal left underneath it! similar story for the spare wheel well.
and bonnets ready for top coat just a few stone chips otherwise in good nick - i'd like to fit bonnet pins too...!
Left to do is both front floors, tidy up whats already been tacked in, all door sills, wheel well, then onto brakes and driveline. clutch had seized on though i've removed gearboxprop etc so to source a good one and clean up the flywheel etc.
i got it a little before Xmas. i hope to have it on the road MOT'd and FREE taxed by April though no doubt it'll come off the road again for some rV8 power or even one of my spare Cosworth 24v'ers
Link to comment
did a little more last night the front panel is fine but were it "joins" the wing is not - i believe that nasty Rot worm has been a chewing underneath some impressive filling!
so a tacked some metal behind to keep it reasonably straight whilst i fabricate/dodge up the gap round the front...
Let the pieces of bodge begin...
Link to comment
  • 3 weeks later...
not a huge amount further on but an update all the same:
the yellow was spare hammerite - it won't stay yellow!
Master Cyl was busted
i fitted a Micra servo (sorry don't hate me) i had it stored away and just needed to drill 4holes for it to fit its the same depth and the cntre connected just needed a tiny bit of opening up to fit
Had visitors this week and i had comments about the shop looking like a scrap yard so i did a quick blow over in blue
and cleaned up the front grill
got one bonnet pin on
and thats as it stands hopefully refit the MasterCyl and servo soon then do the pipework and see what happens with my 20 year old brakes!
Link to comment
sill repair
Quite a large gap between the grill and the bonnet - so i took part of the old front panel and turned it upside down to fit above the grill
It's all welded on now i just need to add some metal to the wings and the edge of the bonnet. Grind it all back and fill where necessary. Hopefully it'll look reasonably normal. I'm hoping to get some Starmags for it too soon.
Link to comment
  • 1 month later...
I've removed all brake lines/hoses its been sat for 20 years and they all had various issues... and since I'm fitting a Micra Master cylinder and servo i will then have a tandem M/C so each cylinder/caliper can have its own brake pipe!!
I've re-attached the o/s rear wheel arch and fibre-glassed it in as best i can. i hope to put the gearbox back in soon and get on with more welding soon (a mates borrowed my welder).
also chopped off the rear exhaust box (as rotten) and fixed the front lights electrics... i now have fully working lights, front and rear, bar the indicators (i think the flasher unit is knackered) although the hazards work!?
Link to comment
  • 2 months later...
 Share
