Danxr2
mk 2 escort popular plus project
2.0 Cortina / Capri / Granada  their all the same apart fron some ancillarys
Apart from sump/ alt mounting and exhaust manifold  no exactly the same.
It's back life got in the way of pulled her out the of my unit and took her home baught yet another engine this one runs just needs a clean can't wate to get back to sorting it
Got the engine on the stand today had the rocker cover off and every thing looks mint and had the bore scope out and cylinders look good still going to take the head off and change the gasket duz anyone think I need to have the cylinder  head skimmed 20190508_191216.thumb.jpg.f3e5af17ae81177eebe674527345e3cb.jpg
Might be worth measuring or CCing the combustion chambers first, incase it's already been done.
If it hasn't, then a skim won't do it any harm and more compression on a Pinto is always good.
If all looks good why pull the head ?
Wel I third id just take the head off wile I was there changing everything else just to be sure apparently it was rebuilt and used for 500miles before the car went off the road for body work and the guy decided he would go zetec it looks clean under the rocker cover no sut or glupey oil or wear on the cam lobes plus I don't no if it has been changed to unleaded il take the sump and that off the week end and put some pics up
Your probibley right is there any way of telling if it's unleaded without taking the head off
Just txt the guy that I baught it of it's still a leaded head
Clean it and get it in and running, how many miles do you plan on doing in it a year ?
If you feel the need change to an injection head later
True a couple of people have sed that now it's not exactly a hard job even wen it's in the car
So total change of plan I took the sump off and found bring gunk like the head gasket had gone  so I checked the big end shells and found they were like new
So I took the head off to see if anything was out of place as expected all was ok the pistons are not the original ones as they don't have 20 hc on then but they have some small Markings on them did any one know what they mean
I took some pics of the valve seats can any tell if they are standard or unleaded
