Sign in to follow this
GWtaylor
4-5 speed box
Is the Type 9 gear box a straight swap on my 1300 escort and what would be the pros and cons?
I will be traveling 800 miles most weekends
Thanks
not a straight swap
you have to change clutch, cluch cable, spedo cable,propshaft,gearbox mounts and move the hole for the gearlever
Sounds a lot of work mate but most of these bits are available off the shelf.
If your driving that many miles ( respect ) you will get the money back in no time with saved fuel etc. :D
Thanks wont be getting one of them yet then
Is it your everyday car? would only cost about £200 to do the lot i would imagine, well worth it if its your everyday car! :)
gearbox from any 5 speed ohc or cvh sierra (not mk3 granada which has electric speedo) escort auto propshaft and clutch disc with splines that sut the box and diam that suits the fly wheel
gearbox from 4 cylinder sierra not v6 cluch cable from rs2000 prop from rs2000 clutch form 1600 pinto sierra not cvh speedo cable from sierra hole for gearlever move back 4 inches gear box mounts move back 4 inches
