chinkamon
5 speed gearbox
I think I know the answer but got to ask,
Mk1 cortina,
Is there a 5 speed gear box that I can replace my existing stock 4 speed with, that will slot into the space no cutting required and bolt to the precrossflow and existing prop??
The only real options available are the Type 9 and MT75 Ford boxes
both have different input and output size and spline count meaning you wil need a new clutch plate and shorten the propshaft with a new nose to fit the gearbox
15 hours ago, eeb43 said:
no
Yea, As I said, I thought I knew the answer would be that  ?
So not straight swop then, I assume tunnel needs a bit of modifying too?
The Tina tunnel is quite small in comparison, it's as easy to fit a large tunnel unlike the escorts which can be manipulated into shape to accept the 5 speed.
do you mean beat it with a hammer??????????? lol
