Looks a big project. Is this going to be a road or rally car?
about 10 years ago, a onetime active member on here (Hellblue) did a stunning 4 to 2 door conversion of a mk2 Cortina. He dropped a BOA Cosworth V6 lump into it for good measure at the same time.
A rally car . I bought it with the back doors welded shut semi tubbed and fibre glass bubble arches. It’s actually not difficult to do the conversation
16 hours ago, andrew james said:
Will be fine for autocross ect thanks for your concern
dont have to be road legal then?
18 hours ago, eeb43 said:
good luck getting that on the road!
Let’s be honest 90% of the cars on here would be Q plated if they had their way🤫
nope! 90% of them would be broken for bits as they have no hope of passing iva to get a q plate!!!!!!!!!!!!!
1 hour ago, andrew james said:
This is getting a bit boring now
Agreed.
7 hours ago, andrew james said:
Just to upset you people even more........
You won't be upsetting me in any way shape or form 👍👍👍👍👍👍👍👍👍
I like the idea, what did you use for B posts. Did you have locate 2 door posts or graft the 4 door ones?
I bought two second hand sides from A post to back panel and welded in the parts I needed, after removing the 4 door B post . I used the 4 door hinges on the doors. Reinforcing was used before the B post was removed, they when everything was welded inside and out the reinforcements were removed.
  • Thanks 1
Here’s  one for  eeb 43, seeing he’s getting so hung up on SVAs. Chill out man🤪
  • Haha 1
only 10 years out of date col!!!!!!!!! anyone would think you had a vauxhall engine!
