Sign in to follow this
preacherman
2.0 Pinto head gasket recommendation
Can someone recommend a good quality pinto head gasket. I have one but it's a bit cheap and flimsy.
The compression would be a little higher than standard as the head has been skimmed by 1mm.
Neil
I’ve done a quick and dirty calculation on compression ratio for you engine.
now there are some assumptions because I don’t know your piston deck height and I don’t know you actual chamber volume, that said it won’t be far off...ish
i use Rheinz when I can and they have a 1.3mm thickness compared with 1.63 standard.
so with all that said my calc put your compression at 10.65 to 1 at most
ok if you make sure you ignition timing is ok
  • Like 2
Can't fault Victor Reinz head gasket and bolts.
Where you at now with your engine?
It still the same with the odd jangle noise  from top end and heavy breathing. Got a missfire now but it still goes well. Do to the wifey having a new kitchen I haven't had any time on the car for 5 weekends. I am starting to accumulating some parts for a new engine. Its basically a stock 2.0 block albeit refreshed and a big valve head with fast road cam. Still on bike carbs though.
15 minutes ago, preacherman said:
I had the chance of buying a good spec motor for 500 or get new wheels.the shows shows the outcome
Wheels look spot on 👍
