Hi, I've recently attempted to get the mixture adjusted to even out the carbs but the front mixture screw is jammed almost on full. :(
The screw head is also in a bad way. Looks like 2 trangles instead of a slot. ( >< instead of - )
Any Idea on how to remove it? I have a new one on its way so it can be destroyed if needs be.
Thanks :thumbsup:
Thanks for the help. :thumbsup:
I ended up drilling holes to make a deep slot. Heated the all up and lots of penetrative oil later and It came off.
Looks like it was cross threaded at some point put all ok now.
