hi guys
hope you can help
i have had the tank and swirl pot fitted with -6 fittings
along with the 044 pumps and filters
i have set up the tank and swirl pot and placed the pumps and filters to where i think i will have them
what do you guys think before i final fit??????
Fuel tank to low pressure pump to upper swirl pot feed. lower swirl pot pipe to low pressure pre-pump filter. From there to high pressure pump then high pressure filter. From there to fuel rail them to fuel regulator and back to uppermost pipe on swirl pot. finally upper pipe on swirl back to fuel tank.....simples :?
just as i would have done it
lower outlet on tank to filter 1
filter 1 to 044 pump 1
044 pump 1 to upper inlet on swirl pot
lower outlet to 044 pump 2
044 pump 2 to filter 2
filter 2 to fuel rail
fuel rail to upper inlet on swirl pot
top fitting on swirl pot to top fitting on tank
just leaves the upper outlet on the tank blank it of ????
custom pump and filter mounts made
really need to stop working on the car this late at night still if im going to have it running by feb and mot'd in april i need to get a push on,,,, may be begging for help soon
