fatboycharlie Posted July 3, 2011 Report Posted July 3, 2011 just going throuh rebuilding my 2wd head i removed the cams and there is score marks on the cam caps and under them the cam looks good tho is there any thing that can be done about it or should i run it as it is wot do you think as im no cosworth expert ?
w p e Posted July 3, 2011 Report Posted July 3, 2011 just clean up the marks with 1500 wet a dry useing a bit of oil and your good to go. scratches and grooves old oil so ther not a problem
