sgallywag Posted February 14, 2012 Report Posted February 14, 2012 just fitted me pedal box and cant seem to bleed fluid to the rears and the front brakes i have managed to pull fluid through but have no pedal pressure please help
Tom Posted February 15, 2012 Report Posted February 15, 2012 Bias box? Have you got the inlets and outlets the right way round? If so put a bleed pipe on each nipple and open them all and let gravity do the rest. It's not strictly the 'right' way to do it but if left long enough (10mins ish) it'll work. Just keep topping up the fluid
rallyesport04 Posted February 15, 2012 Report Posted February 15, 2012 i always gravity bleed brakes if you really struggle bleed it backwards using a syringe an a bit of screenwash pipe
Tom Posted February 16, 2012 Report Posted February 16, 2012 That's howi I bleed clutch slaves. Pipe from the calliper to the slave, open both nipples and pump the brake pedal. Dusted
