Ok last two bits i need, A prop, from type 9 to enlish axle and exhaust system from the xe manifold, any ideas?
Was thinking reco prop for prop and then modifying a 2 1/4" LH RS system for exhaust! :?
i used a standard rs2000 single prop and a ashley manifold and system.they fit shit tho and you have to heat and bend in places.the manifold seems to go towards the gearbox,would be ok if you had a exhaust tunnel :thumbsup:
an RS2000 prop fits a type 9 to english axle mate :wink:
do i need to have it shortened? i've got the distance between the box and axle if it helps :ykt:
