Guest cortinamad-gonetoo Posted August 27, 2007 Report Posted August 27, 2007 does any one know if capri vented discs will fit on a mk5 cortina cheers
over_head_cam Posted August 27, 2007 Report Posted August 27, 2007 Not sure Dave. But they deffo won't fit in the calipers. The 2.8i calipers have a spacer to make the gap wider.
Guest cortinamad-gonetoo Posted August 27, 2007 Report Posted August 27, 2007 yeh cheers i meant will it fit on the hub i knew about the callipers
over_head_cam Posted August 27, 2007 Report Posted August 27, 2007 I don't know m8 But I'm sure someone does Maybe see if you can find an old one and try it?
