Noodles m8 , the only thing you can do is buy a Ashley or similar and fit a Capri rear box on it . its the only one that will " fit " in the gap between the rear spring and tank :roll:
When i say " fit " you have to cut and shut the pipework somewhat ...trust me , i"m at that point myself ! :wink::thumbsup:
Also , the system will need extending because of the difference in length to a saloon...its a right pain in the ar*e :evil:
Hope that sort of helps :wink::thumbsup:
The one I have has 2 boxes and a bung its the bung thats causing the prob but if I take it out its too loud :roll: And as sumo said I have to have it cross over and come out the passingers side in the tiny gap between the leaf spring and the fuel tank, I did have it like that once but the pipe wasnt big enough for the spec now :wink:
I made an exhaust for my escort & it has a straight bit of 2 1\2 steel tube run under the axle straight from the manifold & a kink up to a volvo 960 turbo rear box bolted through the floor with a vauxhall astra strap. Single box & no restrictions & passed an mot fine :thumbsup: (just an idea)
Yer see mine has to cross over past teh gearbox or prop shaft cos of the pinto being opposite sides to the xflow, arrrrr nightmare!
Mine has a pinto & i had a cross over pipe but done away with it & it now comes out the drivers side,the car had a x-flow in when i got it. Just was alot easier to run it straight down the drivers side. Ill try & get some pics over to you if you want tomo??
