jimbo Posted December 11, 2007 Report Posted December 11, 2007 Hi All, How can I tell where my Mk2 was built? I need to determine this, so I can get the right kind of starter motor. Cheers, Jim
james p Posted December 11, 2007 Report Posted December 11, 2007 are they not all the same ? mines eaten about 5 every time i get one it fits ?
jimbo Posted December 11, 2007 Author Report Posted December 11, 2007 Mine is a pre-engaged one (for use with the cold start spec engines) but different ones were fitted to the German and English made Mk2. The car is a 77 'R', which I think was around when production moved. Any other pointers would be good.
escortmad79 Posted December 11, 2007 Report Posted December 11, 2007 If it's a Ghia it was built at Saarlois in Germany (The same factory that built RS2000s), anything else will be UK
w p e Posted December 11, 2007 Report Posted December 11, 2007 look at the ring gear if the teeth are straight its pre engaged if got a chamfer then inertia
jimbo Posted December 12, 2007 Author Report Posted December 12, 2007 Cheers for that Wayne. It's a pre-engaged one as the teeth are straight. Well apart from the worn ones. I assume it means having to take out the whole lump to get to the flywheel. I can't help think it's gonna cost me a fortune to get fixed
