andytechno Posted February 9, 2008 Report Posted February 9, 2008 ime have ing to redirect my fuel hoses on my mk2 pinto conversion,now theres two pipes comeing offa the bottom of the tank.now onw goes to the fuel pump but where does the second one go.also one sits lower than the other so which ones which. help please
Guest MK1gaz Posted February 9, 2008 Report Posted February 9, 2008 Not sure about a mk2 but on a mk1 (probably the same) the outlet in the centre at the bottom is the main fuel outlet to the fuel pump , the small pipe (at the rear inside the boot facing the back panel) is a breather that has a small hose running to the centre of the rear bumper area (takes the fumes from the tank through the boot and out to atmosphere) . There is sometimes a fuel return (fitted to escort sporty models) which returns fuel from the engine back to the fuel sender area at the front side of the tank facing the back seat . You don't need this if using DCOE's so you can block it off with a hose with a bolt in it (bodge) or fit a sender without it from an 1100 or 1300 model .
