MK2Ed Posted March 10, 2008 Report Posted March 10, 2008 Is there an issue with putting 200 BHP through a standard RS Crossmember….?? In either drag racing or road use… Has anyone suffered any problems with this amount of power and type of crossmember or heard of anyone having problems…?? Cheers
Mk 1 Mark Posted March 10, 2008 Report Posted March 10, 2008 I have never had a problem with a standard crossmember in 25 years.... And had a few around 200 bhp so it should`nt be a problem.. Some people have 400/500 in a mk2 on standard crossmember
Guest MK1gaz Posted March 10, 2008 Report Posted March 10, 2008 No worries on mine with a standard x-member . Much nicer to drive as well
MK2Ed Posted March 10, 2008 Author Report Posted March 10, 2008 Phew... Had heard a rumour of mounts splitting or coming off the member and engines hitting the underside of bonnet leaving not a pretty mess... I'll just changes the nylocs and do up nice and tight for insurance
Guest MK1gaz Posted March 10, 2008 Report Posted March 10, 2008 You could fit a world cup x-member but your teeth will fall out instead !!!!!!!!
MK2Ed Posted March 10, 2008 Author Report Posted March 10, 2008 And the hippy hippy shakes for an hour after getting out the car ...
DEP Posted March 10, 2008 Report Posted March 10, 2008 I have a standard crossmember on my cossie, ableit a bit modified and its fine , I think the only problem you may have is the heat from the exhaust manifold melting the engine mount rubber, thats what i ve heard some people having problems with
Guest MK1gaz Posted March 10, 2008 Report Posted March 10, 2008 Yes the rubber engine mount may need some heat reflective material wrapped round it , this will depened on the exhaust manifold you use . I bought some and just cable tied it to the rubber mount and so far so good . You can see it it the photo if you don't know what i mean
MK2Ed Posted March 10, 2008 Author Report Posted March 10, 2008 I have a standard crossmember on my cossie, ableit a bit modified and its fine , I think the only problem you may have is the heat from the exhaust manifold melting the engine mount rubber, thats what i ve heard some people having problems with Cheers Ian the 2 1/4" Ashley is sitting dangerously close at the mo...
MK2Ed Posted March 10, 2008 Author Report Posted March 10, 2008 Yes the rubber engine mount may need some heat reflective material wrapped round it , this will depened on the exhaust manifold you use . I bought some and just cable tied it to the rubber mount and so far so good . You can see it it the photo if you don't know what i mean I think I'm gonna need heat reflective in a few places - funnily enough just ordered some from Burton today...
Tom Posted March 10, 2008 Report Posted March 10, 2008 Gaz, i would've thought you'd need some on those brake lines too or the manifold might boil up your fluid
Baz. Posted March 10, 2008 Report Posted March 10, 2008 I have a standard crossmember on my cossie, ableit a bit modified and its fine , I think the only problem you may have is the heat from the exhaust manifold melting the engine mount rubber, thats what i ve heard some people having problems with Cheers Ian the 2 1/4" Ashley is sitting dangerously close at the mo... you will have problems trust me, ive been there and done it Twice!! and i dont give a fook wot you wrap it in , when that engine is on full chat and the manifold starts glowing, so will your rubber engine mount fit a world cup, more room for the manifold coz the engine sits to one side, and it wont melt
Guest MK1gaz Posted March 10, 2008 Report Posted March 10, 2008 One persons exhaust manifold will get red hot and another persons won't , this is usually down to set up . A restrictive manifold will also get hotter than a freer flowing one .
Retromotorsport Posted March 11, 2008 Report Posted March 11, 2008 If anyone is worried ... get a chassis mount kit, its cheaper than a WCXM .. and also depending who made the WCXM, the chassis mount kit will fit, as your making it ... it also has the mounts further to the sides of the engine bay
Guest MK1gaz Posted March 11, 2008 Report Posted March 11, 2008 and if chassis mounting then your teeth will fall out !!!!!!!
