I`ve sold all the v6 stuff out of my Anglia and decided to put a pinto in. I`ve bought a complete 2 litre engine(205 block) a big valve head(45.5mm and 38mm valves and ported by Ferriday Engineering) a HT1 Kent Cam, twin 48 Webers with ported inlet, adjustable vernier, ARP bolts for the rods and flywheel. Will this lot work with a standard bottom end or will i need bigger pistons and better rods(Cossie?)
Guest MK1gaz
It will work but the engine won't perform as well as it should because the compression will not be high enough on a standard bottom end . It will still go well though no doubt :thumbsup:
need to ask an engine builder like jeff,wayne or the ashtons but i think the lift might be a tad high for a standard bottom end,you might start kissing the valves.
with that type of cam you should be looking for compression ratio of at least 12:1 to get best out of it.
but like gaz said will go ok on standard lump.
