i will try and explain prob confuse myself halfway through
im running a x flow with rs2000 clutch and pressure plate ..been drilled and pinned to fly wheel
and running a t9 5 speed with rs alloy bell.
iv got one these internal hydrolic things that bolts to end of box take the original cast bit of a bolt hydrolic bit in .
so me question is
from bell housing face measured into end of release bearing iv got
82mm
from springs on pressure plate to engine block iv got
100mm
the spacer behing hydrolic thing only add upto
16/17mm
when i 1st used this set up i was putting a redtop on a sb bellhousing and the bits needed where pretty much text book bits from the shop running same t9
all this was 10 plus yr ago
so do i have to set the release bearing just of the springs on pressure plate ..or do i have the wrong back plate to run on a x flow
im no expert on cars but do no how to build um up and make um look pretty but when it comes to how things need to work it gets a bit hard
can someone help
there's a pint in it
and me biggest prob is im trying to get her built and finished for some shows this yr.so trial and error is the long way round
I think I understand what you're saying (a bit ;))
Could you get a spacer machined up to take up the slack?
Tony (petrolhead01) had one made for his 100e
cheers
so does the thrust need to be just touching the pressure when bolted up.if so i need to loose 20 odd mm as it is the box dont reach the block to bolt together.
so i will need the mounting plate turned down.but dont think it would leave much of the flange left for mounting
