bmxdave Posted June 20, 2008 Report Posted June 20, 2008 On the way home today my clutch was ok, until i got off the motorway. When i started to stop and start and change gears more my clutch slowly started getting heavier and heavier. I thought i was just low on fluid or something so i carried on. By the time i got through the tunnel and onto the next motorway i was having to change gear without my clutch. It just got so heavy. I could just get enough to slip the clutch at lights so i could crawl up to them really slow and not stop. When i got home i got my din dins then had a look and it was a bit freer but still really hard, and i can hear the clutch springs squeking. Its disengaging the clutch and doing its job, its just bloody difficult. Its meant to have one of those telescopic jobbie things like the modern stuff. Could it be that? Could it be dirty and picked something up or something? Any help is good cause i need the car for monday for work!
DEP Posted June 21, 2008 Report Posted June 21, 2008 Dont know much about hydraulic clutches im afraid, but have you tried bleeding it throu, try some new fluid,
lee_capri Posted June 21, 2008 Report Posted June 21, 2008 oh deer sound's like the swingarm mate,had this on a land rover stiff pedal,for about a week then the swingarm snapped,if you take the cylender off and look inside with a torch you might be able to see what is going on,i thought it was the cylender as well till i fitted a new one and their was no differance,because the swing arm had snapped
