Would i benefit at all from an oil cooler.
My Water temp sits around 80 to 82 degrees when im going slow and up to 90 when im razzing it and its hot. Today was a really muggy horrible damp day and it wasnt far off 90 degrees constantly. At the moment im doing a lot of motorway mileage, and for me that means 80-100mph all the way making 3500 to 4500rpm and more constantly. So its getting hot.
Would a little Oil cooler do me any good or would it be a waste? Im not having overheating problems but prevention is always better then cure.
Do you have good oil pressure when the engine is hot? If so the oil is doing it's job, you don't want the oil running to cool as it loses its cleaning properties. What thermostat temp do you have?
Not sure about the oil pressure. The pipe split a while ago and i havnt gotten round to replacing it. Im not sure on the temp but once it opens my gauage reads about 60 degrees.
I only used one when I first put a homemade cut sump on just to make up the volume my pressure sits at about 60 dunno about temp yet
