lee_capri Posted August 2, 2008 Report Posted August 2, 2008 fuel pump needed to run a v8 what size would i need,and were to buy one from looking for one to mount on to the inner wing any-idea's
lee_capri Posted August 2, 2008 Author Report Posted August 2, 2008 alright aftermarket one,bolt down type,i knew what i meant
lee_capri Posted August 2, 2008 Author Report Posted August 2, 2008 just been looking at some farat one's how do you work out what psi you will need
bmxdave Posted August 2, 2008 Report Posted August 2, 2008 Normally youd run a fuel pressure regulator if your running carbs, and i think they come preset but can be adjusted.
lee_capri Posted August 2, 2008 Author Report Posted August 2, 2008 running injection mate was useing a 2.8i tank and pump but cant bebothed to fit that and was looking to mount in the boot so i can switch it off like dead
bmxdave Posted August 2, 2008 Report Posted August 2, 2008 Im not sure then. Id still run a regulator and a pump with a few psi more then needed though. Im sure someone can clarify better, but im sure most people are away at ford fair now though.
