SmokeEm Posted September 30, 2008 Report Posted September 30, 2008 What do you all reckon is the best ignition setup for a pinto that won't break the bank? Engine spec will be, 2.0l std bottom end, Vulcan Maxiflow2 head, HT1 Cam, Twin 45's, 4/2/1 fanny mold. It's currently running s.i.e.r.r.a leccy ignition but am under the impression this won't be good enough once the new head n cam are on? We don't have the mechanical knowledge to fit & set up a MJ or similar system so are we best leaving as is or going back to points set up with a preset Bestek/Aldon dizzy? (Or can we get existing dizzy modded) Help Car is Capri, used daily but weekend drag use
fezza Posted September 30, 2008 Report Posted September 30, 2008 Bestek mate ive had 3 kits off him in the past and they are spot on and value for money you cant beat them,he will also set up the distributer to suit your engine spec http://cgi.ebay.co.uk/Ford-Pinto-OHC-Ra ... 286.c0.m14
