Atm im running standard solid discs on the front of my mk2,
can i fit almost any front calipers if i make the correct bracket for them, i have some from a mk5 fiesta sport and some from a calibra red top, both of these have vented discs?
also can i use a bias pedal box ok? as my current master cylinder is not as good as it could be?
Thanks Paul.
Anything can be made to fit, if you ve got the right tools :wink:
However the calipers you ve mentioned, might be to big, for your solid discs, i:e vented discs tend to be thicker, Why dont you just get some vented discs and recon M16 calipers (spaced) and a decent set of pads :wink::thumbsup:
