Retro-gone. Posted December 5, 2008 Report Posted December 5, 2008 offhand does anyone know the bore size of the fuel pipe needed for 32/36 weber please.
Retro-gone. Posted December 5, 2008 Author Report Posted December 5, 2008 hang on, 8mm seems a lot, i mean the inside diam ..
LEONMEX Posted December 5, 2008 Report Posted December 5, 2008 we sell it at work & it is the int dia,im sure? 8mm on the feed from the tank & 6mm on the return if you are running a return? but can be blocked off can stick some in the post if you so wish
Retro-gone. Posted December 5, 2008 Author Report Posted December 5, 2008 i just need it from fuel pump to carb and wherever else under the bonnet, it didnt come with the carb so unsure how much i need?
