Yeomans22 Posted January 25, 2009 Report Posted January 25, 2009 Evening i fitted my 1600xflow in again today, my last 1100 xflow only had one pipe going from the distributor to the carb, my new engine has 2, where do they both have to go please? i have put one to the carb as before but not sure on the second one. the silver bit on the end of the distributor where does it go? thanks Paul.
72mk1escort Posted January 25, 2009 Report Posted January 25, 2009 I dont recognise that distributer but if you want to be on the safe side go to your local tropical fish shop and buy a t-piece and join them together and then attach it to the inlet manifold. Hope this helps
Yeomans22 Posted January 27, 2009 Author Report Posted January 27, 2009 nah it was from a sweedish mk2, which had some emission devise bolted on under the inlet, im guessing it went to something onn there, ill just connect them together and see how it goes. thanks
emu Posted January 27, 2009 Report Posted January 27, 2009 Its not vacuum retard is it? I cant think why it would be or what the benefit would be but just a thought? If it is then joining them together wont work properly
Yeomans22 Posted January 27, 2009 Author Report Posted January 27, 2009 i have no idea what it is, i've only seen distributors with 1 pipe on before, i just try with it connected together, blocked off and hust with nothing and see how the car runs.
bigdaz27 Posted January 27, 2009 Report Posted January 27, 2009 i think its for a auto box they have 2 the pinto in my escort is the same and that came out of an auto sierra older auto gear boxs use vacum to change gear
Savvi Posted January 28, 2009 Report Posted January 28, 2009 You will need to block one of them off, i'm not sure which one as i suspect that one will advance the timing one will retard it. With the cap off have a look which way the base plate moves when you pull the linage as if a vacuum was applied. Or try blanking one off and see how the car drives then do the same with the other one use which one feels best ?
Yeomans22 Posted January 28, 2009 Author Report Posted January 28, 2009 ok, ill blank one off and try it and then blank the other one and try it, thanks
