Justmark Posted February 17, 2009 Report Posted February 17, 2009 Can anyone advise me on the best way to put rs2000 stripes on my car. I have been told to use water,if this is true do i wet the car then apply the sticky side straight on to it. and if so how stiky will they be when its dry the stripes are from D M B Graphics
over_head_cam Posted February 17, 2009 Report Posted February 17, 2009 The adhesive on the vinyl is waterproof, so when it dries the stickers will be completely stuck Just squeegee out as much water (and air) as poss
Justmark Posted February 17, 2009 Author Report Posted February 17, 2009 The adhesive on the vinyl is waterproof, so when it dries the stickers will be completely stuck Just squeegee out as much water (and air) as poss thanks will try saturday
rodbasher Posted February 17, 2009 Report Posted February 17, 2009 when i do vinyl s i use 1teaspoon of fairy liquid too 2pints of water in a spray bottle . spray onto the back of graphic as you peel of release paper stops it sticking to itself if wind catches it.then squewwgy over the vinyl when positioned, what ever you do dont apply it dry you will regret it !!!
djstaffy Posted February 18, 2009 Report Posted February 18, 2009 I do vinyl graphics for a living, what you want to do as said above is take a plastic spray bottle fill it with water & add 1 -2 drops fairy liquid # then when you position the stripes , freehand or measured ,when you peel the backing paper off just spray a fine mist onto the adhesive side of the vinyl the squeegee down to get all the air bubbles out , leave for a minute or two then wet the application tape on top, rub in the liquid & the tape should come off nice & easy when finished gently go over all the vinyl with a hot air gun on warm setting to seal it all off, if you get any bubbles just pop them with a pin djstaffy got some pics of essys i've done will post them later
djstaffy Posted February 18, 2009 Report Posted February 18, 2009 here's a couple of mk2's that i did the graphics on the rally replica i copied from a model car & designed all the logos on my pc i do lots of scooby replicas but the essys are me faves djstaffy
Justmark Posted February 18, 2009 Author Report Posted February 18, 2009 I do vinyl graphics for a living, what you want to do as said above is take a plastic spray bottle fill it with water & add 1 -2 drops fairy liquid # then when you position the stripes , freehand or measured ,when you peel the backing paper off just spray a fine mist onto the adhesive side of the vinyl the squeegee down to get all the air bubbles out , leave for a minute or two then wet the application tape on top, rub in the liquid & the tape should come off nice & easy when finished gently go over all the vinyl with a hot air gun on warm setting to seal it all off, if you get any bubbles just pop them with a pin djstaffy got some pics of essys i've done will post them later thanks for advise will try saturday if you live anyware near birmingham i would pay you as it sounds easy but probably hard to get right
Justmark Posted February 18, 2009 Author Report Posted February 18, 2009 when i do vinyl s i use 1teaspoon of fairy liquid too 2pints of water in a spray bottle . spray onto the back of graphic as you peel of release paper stops it sticking to itself if wind catches it.then squewwgy over the vinyl when positioned, what ever you do dont apply it dry you will regret it !!! thanks i did try the boot one dry before i got advise and your right i nearly had to buy another
stickerboy Posted February 18, 2009 Report Posted February 18, 2009 Is it a mk1 or mk2 Kit? I can fit them if you need them fitted. Cheers Dave
Justmark Posted February 21, 2009 Author Report Posted February 21, 2009 Is it a mk1 or mk2 Kit? I can fit them if you need them fitted. Cheers Dave thanks for the offer it was a mk1 kit i gave it a try on one side after some good advise on hear pleased with the outcome so thanks to any one who helped me with sound advise
rodbasher Posted February 22, 2009 Report Posted February 22, 2009 well done for trying mate .even doing shop windows for a living, my a**e ole murmmered when i done my pontiac graphics the eagle was a night mare gonna show us the results
djstaffy Posted February 23, 2009 Report Posted February 23, 2009 Nice one , lets see some pics then djstaffy
