bolt it down lol.
you using harnesses? i was thinking making an ally square block with a camera mount on it, and mount it on the B pillar where the seatbelt used to mount :)
then fine-tune the angle up n down by turning the ally block
angle it left and right using the camera mount (loosen it off a bit) :)
I film long lengths of road for work, we use a camera attachment on suction cups. sticks to the inside of the windscreen & has a damping effect so the camera doesn't shake.
There's a compant that specialises in them.
When i've done Tv filming they use a mixture of Suction cubs and adjustable mounts screwed to the bodywork.
I think you might find a lot of your probs is the camera you use, they have a camera that runs back to recorders set on the floor or in the boots.
Camera looks like a cctv type, most of the shows you go to have stands who specialize and there not mortgage money to buy.
This is something i found on ebay and the sort of thing i've seen used:
http://cgi.ebay.co.uk/MANFROTTO-BOGEN-P ... 240%3A1318
