i have now got the cosworth engine for the mk2 escort but dont know what to do with ecu and how to wire it up
i have the oe rs2000 loom but not sure if i cut and join???
is there anyone who can help....
pics pdf anything please a someone who can do it with me ???
thanks guys
Fuel Pump = Black Red Striped (Thick Wire)
Water Temp = Brown White Striped
Oil Pressure = Brown Green Striped
ECU Diag Light = Brown Red Striped
Rev Counter = Green
Ignition Feed = Solid Black or Solid Red (Thick Wire)
Perminant Live = Red Blue Striped (Thick Wire) or 2 black wires on a 3 Door loom
4x4 Engine Loom With connector cut off
Depending on which loom you have there may not have the ECU diagnostic wire
Also I did give Kev a bit of help with his own red Xpack Mk2 that he built a few years ago.
So he can give you loads of advice as well as sorting your wiring out :wink:
