samurai Posted September 18, 2009 Report Posted September 18, 2009 On a FIA battery cut off switch is says to connect 1 wire to - side of coil and 1 wire to ign....when i do that the car wont start and it seems to drain the battery also! Soon as i take the wire off the coil the battery has life and the car starts.. Any ideas?
M.Bird412E Posted September 19, 2009 Report Posted September 19, 2009 Sorry but you've wired it wrong. I think you need to have a re-think or read the instructions properly. Follow this link it will provide you with a diagram of where each wire should go. http://www.holden.co.uk/wiringDiagrams.asp# If you get really stuck I can come and sort it just PM me.
samurai Posted September 19, 2009 Author Report Posted September 19, 2009 I have this diagram,it came with the switch. 1 wire to the coil but does not say if its - or + i guess ill try it on the +
