Savvi Posted November 30, 2009 Report Posted November 30, 2009 Mad question but does anyone work on fridge freezers by chance ? We got a yank style one free with our new kitchen, but Mfi went out of business and it's gone wrong. The whole thing freezes including the fridge bit, i had a look and on google and they mention the thermostat ? Anyone know if it's an easy job or do i need to call some rip off merchant who wanted £90 to to turn up, then an hourly rate after that.
X-pack-Glyn Posted November 30, 2009 Report Posted November 30, 2009 defo the stats gone pop... ive got 5 freezers here but ive been fairly lucky, allthough i did have one go down summer 2007... theres about 600 quids worth of bait in em and one went down...big panic stuffing round balls into anyone and everyones freezers
jimbo Posted December 1, 2009 Report Posted December 1, 2009 £90 call out fee? Feckin outrageous!! Chances are if you can fix a motor, then you can fix a fridge. I've not done a fridge yet, but have fixed my oven element, and washing thermostat and machine motor, through the same process; Google the fault symptoms, Google for a parts supplier, check (and recheck) I've got the right part. Then when it's come to replacement, careful methodical disassembly and reassembly. I would imagine the the thermostat is a relatively simple wired component that either has a probe running into the fridge cavity, or that sits entirely in the fridge, inside the box with the temperature setting dial . If a base level fix is £90 it's got to be worth a punt......
