now have the new custom made radiator
60mm core
adjustable side mounting
now need to find out what hoses will work with the cosworth 4wd enginge
i know as you look at the engine the right out let on the egnine goes to the top of the rad
and the left out let goes to the bottom hose on the rad
what hoses have you guy used rs2000 hoses or cosworth hoses
also i will need to block of hose out lets on the engine as not running a heater.
you could always join the water hoses for the heaters to help keep water circulating? You will have to make them up as i have done with odds n sods
i got a few second hand hose kits & some alloy joiners & cut away.
just the bottom hose to do & im going to use 4x90 deg bends with some alloy tube to join them :thumbsup: looking good though 8)
