fostersice Posted April 18, 2010 Report Posted April 18, 2010 hi guys i have a single prop going from atlas to t5 gearbox when removing the prop to replace the atlas pinion seal i can see that the prop is only going into the gearbox 2" should it be in move than that???? i can get a alloy spacer made up as i have both the prop and prop mount to axle off i am waiting to get a pinion seal so have time to get it made if needed just dont want to have to get under the car again at a later date when it can be done right
LEONMEX Posted April 18, 2010 Report Posted April 18, 2010 i would say yes it should go into the gearbox more than that,i spoke to neil of 1 0 5 speed & he was very helpful & i will be getting a prop made by him from scratch. My mate had a spacer made & it was a bastad to balance
fostersice Posted April 18, 2010 Author Report Posted April 18, 2010 its the same guy who made my wheel spacers and they where spot on should i aim for a 1" spacer?
LEONMEX Posted April 18, 2010 Report Posted April 18, 2010 i would say it should go in the box atleast an inch or maybe 2? be worth checking with someone who has one done as to much & it can smash the box ive heard?
