ilovegrannys Posted April 23, 2010 Report Posted April 23, 2010 Has anyone got BMW daily driver? Well about an hour ago i stopped behind another car, i then pulled around and the power steering went like 'solid'. Has anyone had this snag? In the manual it simply said 'take it to your nearest BMW specialist' - great!!!
ilovegrannys Posted April 23, 2010 Author Report Posted April 23, 2010 what car is it mate? age? 2001 e46 320
Tom Posted April 23, 2010 Report Posted April 23, 2010 I'm going to upset you a little now. Its most probably a blocked PAS cooler pipe which, in turn, has caused the spindle on the PAS pump to snap. Check the pump is turning (belt's there) then take off the belt and see if the pulley on the pump pulls out of the pump - if so, its knackered. You will need to replace the pump and ensure the system is thoroughly cleaned out BEFORE starting the car. The best way is with brake cleaner and an air line.
ilovegrannys Posted April 23, 2010 Author Report Posted April 23, 2010 I'm going to upset you a little now. Its most probably a blocked PAS cooler pipe which, in turn, has caused the spindle on the PAS pump to snap. Check the pump is turning (belt's there) then take off the belt and see if the pulley on the pump pulls out of the pump - if so, its knackered. You will need to replace the pump and ensure the system is thoroughly cleaned out BEFORE starting the car. The best way is with brake cleaner and an air line. Like i thought Tom, a new pump in bound! Cheers for the advice mate The belt is tuning and its taught. I will have to look a bit deeper tomorrow.
Tom Posted April 23, 2010 Report Posted April 23, 2010 No worries, I did one of these recently and didn't know the system was blocked. The new pump lasted about 10 minutes
ilovegrannys Posted April 23, 2010 Author Report Posted April 23, 2010 No worries, I did one of these recently and didn't know the system was blocked. The new pump lasted about 10 minutes When i turn the steering wheel there is a clunking noise, it sounds like its coming from the rack area.
Tom Posted April 23, 2010 Report Posted April 23, 2010 Might be the rack mate, I Could only think of the most recent problem I've had. Start it up and take the resovoir cap of and see if the fluids moving that'll tell if the pumps ok or not
ilovegrannys Posted April 23, 2010 Author Report Posted April 23, 2010 Might be the rack mate, I Could only think of the most recent problem I've had. Start it up and take the resovoir cap of and see if the fluids moving that'll tell if the pumps ok or not I will check that tomorrow when its light. Again, cheers mate.
ilovegrannys Posted April 23, 2010 Author Report Posted April 23, 2010 Might be the rack mate, I Could only think of the most recent problem I've had. Start it up and take the resovoir cap of and see if the fluids moving that'll tell if the pumps ok or not I will check that tomorrow when its light. Again, cheers mate. Now i think about it, i took the power steering belt of the granny and she was a bit of a pig but drivable. The Bemmer is like a tank and i have to reverse and straighten up and then do the same move again, i hope it is the rack Tom - finger X'ed!!!
