dave waudby Posted August 14, 2010 Report Posted August 14, 2010 is there a seperate room for body work how do you fill smallish dents size of say 50p piece i thought i did a good job but then now the paints settled the dents still vissable (not as dented but can still tell where it was) any tips its just im trying to get my car as straight as possable so next year it can be sprayed gloss black in a body shop, sick of the piss can look ive got 3 dents in my roof, one outwards dent in my bonnet, rear doors could do with changing for a better pair then it would be about there just a nice coat of paint
dannysmk1 Posted August 14, 2010 Report Posted August 14, 2010 hi im sure a body shop will prep the car for paint and repair any dents befor painting the car....
Big_man Posted August 14, 2010 Report Posted August 14, 2010 I'm a novice aswell but gettin there (slowly), I found its easier to put thin layers on then sand it down and repeat till you get what you want. you may get some better advice but this has worked well for me
steve mk2 Posted August 14, 2010 Report Posted August 14, 2010 Put the filler in get a sanding block, when you rub it down (p80 or p120) keep changing your direction you're rubbing it down and dont press hard to prevent getting ripples and uneven sanding, keep feeling it with youre hand flat on the panel until its almost ready (tiny bit high) then flat it with p320 grade sandpaper and when you can't feel a change in the panel with you're eyes closed you know it's ready. Then a couple of coats of primer then dust a layer of black on and flat it with hardly any pressure with p500 the black should flat off evenly , if not it may mean it's a tiny bit low
