MEXY867M Posted March 20, 2011 Report Posted March 20, 2011 Well I have the normal starting motor which was fitted to a pinto running a type 9 5 speed box,question being a friend is running 1600 crossflow with a type 9 5 speed box and there using the old style starter (long fully exposed spring/cog assembly)will this starter I have fit their motor.thanks peeps
PaulMags Posted March 20, 2011 Report Posted March 20, 2011 I would think it depends on the flywheel your using
caprinerd Posted March 20, 2011 Report Posted March 20, 2011 do you mean the inertia type as apposed to the pre engaged type
MEXY867M Posted March 21, 2011 Author Report Posted March 21, 2011 yes rog, I know rs alloy bellhousing starter will fit either side,
w p e Posted March 21, 2011 Report Posted March 21, 2011 no the ring gears different as is the placement of the r/gear on the f/wheel.
