just put new rear arches on my mk2 and had to weld in new inner lips as well so when i spotted the new outers to the inners theres no paint much in the seams. Will waxoyl from sprayed in the arch from the boot get in to the seams any ideas as not a body work expert at all.
Hi mate before you do any work like buy some weld through primer. you get it in aerosols and spray on the areas your welding. if you have already done the job use etch primer then sealer on the joint. Wipe any excess sealer out with de greaser. HTH Mick.
pics? :wink:
i regularly squirt oil (20w50) on the inside of the rear arches (and in the chassis rails) mate just for piece of mind you know :wink:
got pics on my phone but just got on and did it.
so does the oil work tom i was going to try waxoyl see what happens
and i was right before i started I FECKING HATE BODYWORK !!!!!!!!!
it seems to mate. it won't do any harm. you should see the state of the underside of the escort - covered with engine oil, grease, gearbox oil all leaked out but no rust :wink:
