mk2 matt Posted July 11, 2011 Report Posted July 11, 2011 I've got an oil leek on the cam oil seal on my pinto, so tonight i thought i would fix it. two seals later it's still the same The seals i've used are ones left over from head gasket sets bought from my local factors. Anyone had this problem and no of a better seal to use or why the ones i've used don't work Thanks matt
jayson2.3pinto Posted July 11, 2011 Report Posted July 11, 2011 have you checked the front bearing for wear
mk2 matt Posted July 11, 2011 Author Report Posted July 11, 2011 no if the bearing is worn what will that do to the seal? how do i check it do i have to take the cam out? Matt
