5tox Posted October 13, 2012 Report Posted October 13, 2012 Ive almost finished off the o/s front of my escort, the problem i have is that someone has previously welded on the anti-roll bar bracket and i cant get the bolt out Ive tried a punch and a big hammer but its having none of it so i plan to cut the tube out and weld in a new one... trouble is the cars miles away and i diddnt take any measurements can anyone tell me the length and width of the bolt used so i can buy a piece of 3mm thick tube to weld back in when i cut the old one out im after something like this... http://www.ebay.co.uk/itm/Mild-Steel-Ro ... 45f8edd64e
5tox Posted October 17, 2012 Author Report Posted October 17, 2012 Apparently the inner diameter of the tube is imperial but nearest to 12mm if i got some steel tube with a 12mm inner diameter does that mean an M12 bolt will fit in nicely? i have some double width anti roll bar brackets but no bolts and nuts to hold them in place
72mk1escort Posted October 17, 2012 Report Posted October 17, 2012 Apparently the inner diameter of the tube is imperial but nearest to 12mm if i got some steel tube with a 12mm inner diameter does that mean an M12 bolt will fit in nicely? i have some double width anti roll bar brackets but no bolts and nuts to hold them in place How about drilling it through mate with the correct size drill bit to remove any weld or left over thread that's inside the steel tube? that's what i think i would try first
5tox Posted October 18, 2012 Author Report Posted October 18, 2012 Initially thats what i was going to do but on a close inspection someone has had a go before and missed the bolt completely drilling into the tube itself. Rather than trying to repair the tube thats in pretty bad shape it may just be easier to replace the lot
gpcmatric Posted October 18, 2012 Report Posted October 18, 2012 Have a word with escort-Tec they may have what you need
