5tox Posted January 26, 2013 Report Posted January 26, 2013 I have had a go at the nearside front chassis rail and was fairly happy with the repair at first, now ive tackled the other side and noticed something... however well i thought i had repaired the chassis rail there is rust throughout even where you cant see it because ford decided to stick a chassis rail within a chassis rail (for strength i guess) the trouble is with 2 skins its a breeding ground for rust are front chassis rails available without having to pay ridiculous prices? should i just repair the offside the same as i did the nearside and forget about it? should i completely replace both chassis rails with some heavy duty box section i have aquired? im a little nervous about completely replacing them as im worried about everything lining up and fitting correctly, i guess i could make up a jig of some sort first heres the side i havee already patched up and i was aiming to do the same the other side heres the stuff i have to completely replace it with, if thats the route i choose the steel i have to replace both sides completely is very close the the original and sits inside of the old chassi rail very tight, it would just require a little bit chopping off the eends as its a fair bit deper than the original rails what are peoplees views, what would you do?
Savvi Posted January 26, 2013 Report Posted January 26, 2013 Theres a guy on Turbo sprt trying to make new ones of these up, you can buy them but think they are about £300 per side, he hopes to have them done for much less then that ? Last post i read said he had done the drawings and was going to make a trial pair to see how long they took so he could price them up
puddy Posted January 26, 2013 Report Posted January 26, 2013 What is that bit of angle iron for in the first pic? I hope it ain't structual . puddy
5tox Posted January 27, 2013 Author Report Posted January 27, 2013 cheers savvi, ill go and see if i can find the guy puddy which bit do you mean? the lower section of the chassis rail?
puddy Posted January 28, 2013 Report Posted January 28, 2013 cheers savvi, ill go and see if i can find the guy puddy which bit do you mean? the lower section of the chassis rail? Yeah,just worked out what it is now, gotta say that weld does not look to have a lot of penetration. I reckon a couple of upward swipes with a hammer and it would be back off again. puddy
5tox Posted January 28, 2013 Author Report Posted January 28, 2013 Trust me its very strong, the steel is around 3-4mm thick and to get it to stit flush with the x-member i had to lean on it with a 3ft adjustable spanner its all pretty irrelevant now as im hopefully going to be sourcing some neew chassis rails diddnt like the idea of welding those nice new inner wings to shit chassis rails
