I have a Pug 106 - 1.1 petrol - the wipers and indicators have stopped working.   Lights are fine.   Is it just a fuse or relay or something do you think?  :|
Thanks Phil.   Erm, I'm not sure about the stalk thing, I will look when I get home ..... where will I find the fuse box and what am I looking for?   Will it say wiper/indicator fuse on it or will it be obvious by it's burned out look? :Bravo:
Hmm, having read the symptoms and done some extensive Internet-based research, I'd say your problem is that you've bought a French car...
I'm well helpful me.
Haha, good shout :-)
Mk2 Shape? If so, The fusebox is in/ around the glovebox I think. Autodata reckons Fuse number 9 does both your wipers and your indicators so I would start there. It also does your brake lights so I would assume they arent working either.
