5tox Posted April 1, 2013 Report Posted April 1, 2013 on the right hand side i have blanked up a circular hole near to the top (i believe for the light wiring) and also the fuse box hole, the fuse box will be located inside of the car and the hole for the light wiring ill cut out a bit lower just above the chassis rail. On the left hand side i have a load of holes, before i get blanking them all up, which ones do i need and what are they there for? if im running a brake bias pedal box with the brake fluid resevoirs ontop of the bulkhead can i just tack weld a plate on the inside of the car to blank up the holes?
