Sounds like you talking about the spacer, there should be 2 of them, one in the front of the block and the other one mounts just above the tensioner ..
They have a thread which turns into the motor and then there is a M6X12mm bolt that turns into the spacer keeping the timing belt cover on. IIRC the top one is used for the tensioner's spring to rest against.
